https://www.infineuminsight.com/insight/mar-2014/specification-update-march-2014?alttemplate=PDF
Talking of up to $8M to prove AN oil through all the testing required for GF6, or PC11
Some Interesting Points re GF6 (and commentary towards GF7).
* xW12, xW8, and xW4 are on the way, in viscosity definition stage.
* Some of the current test engines may not accept oils below HTHS 2.6
* Talk of dropping (legacy grade) 10W30 from GF-7.
PC-11
* stay in grade requirement for xW40 to be increased to 12.8cst except for 0W40 which stays at 12.5 (why KV100 not HTHS ???)
* Detroit Diesel scuffing testing to be dropped from protocol (Means IMO that there's a new DD spec coming soon, as they've seen scuffing/siezures on 30s)
* Mention of the test length of the Mack derived T13 oxidation test (360 hours in an operating engine at 130C - lengthy and expensive).
Another article that discusses some of the ramifications of the new specs, and testing with base oil (and viscosity changes) can be found here
PC-11
