Originally Posted By: GenaFishbeck
Hello mymdx - We would suggest you have your engine checked out by a certified automotive technician. There appears to be too much going on here to confine the discussion to just a “type of motor oil” choice.
Please remember that once you put an aftermarket additive on-top of an already fully formulated motor oil product, you have altered the chemistry of that motor oil. Hence, you will lose any warranty that comes with that motor oil - implied or otherwise. By adding an aftermarket additive, you will also altered the performance claims of the motor oil.
Just a caution about using aftermarket additives (they may work for you, but if there is ever a problem with your engine, you will have to go to the aftermarket additive supplier for any claims) Hope this information is helpful! - The Pennzoil Team
thanks for your reply. I am thinking replace MAF sensor first, hope check engine light will be off. Anyway I have 4 OCI PP left, PP might do the cleaning job.
