We had a nasty bout of freezing rain, followed by temps dropping to 0*f , and the roads are a mess. Sheet ice everywhere, and it's too cold for salt to do much.
Would airing down the tires somewhat make much difference in traction...? Or conversely, would pumping up the tires more decrease the contact patch and create more pressure, thus more grip... ? On ice, I'm thinking more surface area is better...
I am currently a couple of psi below the recommended 33 f / 32 r , running 31 / 29 for now. Seems to work slightly better... heat is not an issue at these temps, and the tires have adequate load capacity even at lower psi... I may try even lower to experiment, and later higher...
Or, is the difference in performance not enough to bother with at realistic tire pressures... I know the off-road guys will air down to 10 or 15 psi in sand etc., but I won't go that low obviously...
And, tire pressure is set cold, at outside temps... brrr. So no loss of psi as car moves from warm to cold.
Thoughts...?
Thoughts...?
