Hey guys- I have 2 carbs- one Edelbrock and one Carter that I'm going to piece together to make 1 for the Ford truck in my signature. The problem is they have lots of this tan colored corrosion or oxidation on/in them and the regular carb dip and cleaners wont remove it. It's mostly an aesthetics issue though, to be honest.
I'd prefer something that I can find in a grocery store like apple cider vinegar or Coke, or from a parts store instead of having to order some heavy duty and expensive chemical or having to bead blast it, which would remove all the factory coating and leave it susceptible to future oxidation.
The oxidation/corrosion can be removed mechanically, but it's really not feasible given all the nooks and crannies.
I have already tried white vinegar- which seemed to loosen it up but without physical removal, it will just stay in place. I know you can use apple cider vinegar to remove rust- if you're patient enough.
They look like this when new:
And here is what I have now:
Here is what it looks like after some light scraping:
Now I know that I'll never get a factory quality finish- and that's not the goal here either. Really, I'd be happy if I could get it to look like the cleaned spot...
