Originally Posted By: Doog
Originally Posted By: stygz
Do people really think it is cleaner or better just because it is more expensive?
Not me. I have owned 3 Lexus vehicles that all call for 91 octane. In an accumulated 430,000 miles (so far) none have had anything but tier one 87 octane. Each have gotten a Techron or Regane fuels system additive every 20,000 miles and new air filter every 20,000 (Fram). All were tuned up with new spark plugs once at 120-140,000 miles and the throttle body cleaned.
The results: Zero pinging. 28-32mpg. clean TB.
The experiment continues.
FWIW the engines 2- 3.5L and one 3.3L V6 all run on 5w30 syn oil OCI 5000
What happens with your car may vary to someone elses. Lexus and Toyota both recommend "Top Tier" Fuel. So I feel this would be more important than the octane rating UNLESS premium fuel is required.
Mind you too, that most Lexus and Toyota are equipped with VVT or VVT-i technology, so using a lower octane may not "hurt" your car, I bet if you dyno'd your car with a tank of 87 vs 91 or 93 octane fuel, you are losing at least 10% hp. Now that may not be measurable by the "Butt Dyno" but your car sure notices the difference.
Your opinion is subjective. Though, your right, your car is proof it can run on 87, but why sweat an extra $1.50 to $2 a tank of gas if you can afford a Lexus to begin with?
Jeff
