Will be reading the threads on "does brand of gas matter" (I am of the contention of that it does not, but I both regular dose and maintenance dose Redline SI-1 to off-set that, and make it BETTER than the SUPPOSED brand gas, since it is only an additive package added from regional suppliers....) and about compression ratio vs octane soon. But, this is more to address if I should continue adding 1oz. Acetone every 2nd or 3rd tank.
Yes? No? And, the larger question... DO we need to add anything to pump gas?
