M1 0w40 1ZZ Prizm 13 months 8265 miles
Michigan
I'm liking these numbers, car was run almost daily in Detroit through last years awful winter, then sporadically used all spring summer and fall. 1qt top off about 1/3 qt at a time, last top off (emptied the 5qt jug) around the 7000 mile mark. I suspect high silicon may be related to installing a new (presumably silicone) fel pro rubber valve cover gasket, with two dabs of RTV where the chaincase meets the block, just before I changed it last. Same filter (stock size denso) both runs
Too thick. Try the suggested viscosity. It'll run better with more pep. Could be the difference between taking a 10 speed off the line or not.
I run this car hard, it gets fed the oil it's specced for when running it hard (euro spec lotus). I think we even went over this last time I posted a UOA. People went quiet after I pulled the data and found M1 0w40 to more or less match the cold viscosity curve of the late 90s 5w30 dino juice the manual says to feed it.
