Originally Posted By: KD0AXS
I have the same engine (3V 5.4) in my F-350. Mine really seems to like Maxlife 5W-20. The Mobil 5000 should work well too. I use the Motorcraft FL-820S. I do 5000 mile OVId and change the filter every time.
+1 if you want to use dino juice. I believe 5k is the factory recommendation? Later years went to 7,500 like in my V10. Severe is now 5k miles, which I run hauling 14k pounds. Stick with the Motorcraft filter and the body will rust out first.
Originally Posted By: Bluestream
Rotella 10W30. and what evedence do you have that it needs to be cleaned?
The OP is in NY, there is absolutely no reason to run a 10w-30. Ford has recommended 5w-20 for 15 years now, it works.
