Originally Posted By: niero
Lubener,
Yeah, it did run normal when I pressed the gas. Thanks for the tip. I'll ask them to clean the idle air bypass next time I'm in.
And that's good to hear about the 5w30. I figured since it was full synthetic it would be too thin for an old engine.
I think that the bad fuel pump is a good bet. When they tested the battery it said to replace. The shop said that they think with the battery on its way out, the throttle control motor wasn't getting the correct charge, and the engine was getting too much air (or maybe it was fuel - which one does Lean Running mean?)
They checked the sensors, and the computer, but no sensor codes came up.
I do remember that last year, about May 2014, it was having a similar problem, only that it was dying at random while driving. Turned out to be a bad crank sensor. (Which means the timing of the cylinders would be off, right?)
As I understand it, the fuel pumps in these era Cherokee and GC's is problematic. It "pulls hard", so to speak, but has always started.
Since the fuel pump is spendy, and I can't replace it at the moment, here's my band aid fix -
Band Aid:
Getting a portable jump starter so that when it's really cold, I don't even bother starting the Jeep on its own. I hook up the jump starter to ease the wear/drain on the battery. That should at least extend the battery life until I can get the pump fixed.
Does that sound like a good idea? Or can that cause other problems?
I know I'm throwing out tons of questions. I really appreciate the help.
I've always loved cars but I don't understand them very well. Mechanical things make too much sense. Thus, they confuse me.
Portable jump starters work best when they are toasty warm. If you leave it in your Jeep and it gets down to 5F (like today in NY) the portable jump starter will not help much.
With respect to portable jump starters, the heavier the better.
