Post your AR builds
JHZR2
Staff member
New Jersey
I got a new lower and am looking for ideas... Pics appreciated.
I'm sort of thinking varmint build with a ss barrel... But no idea really.
My AR in 7.62 x 39. I did not build this from the ground up. I did change the round checked handguard out for a quad rail. My son installed the alg defense trigger. Shown with the 30 round magazine. I plan to go with an eotech red dot scope.
[img:center]http://[/img]
JD Machine .308. Assembled 100% myself. I have many more in 5.56 and 7.62x39, including one in an A1 style wood stock. As soon as I find where I saved the pics I'll post them up.
Bcm by [email protected], on Flickr
BCM 16 in light weight upper with daniel defense lite 12in rail
chopped armalite rear sight
magpul afg and vertical grip
magpul rail cover
magpul ctr stock
magpul moe grip
magpul 10/30 mag
eotech 512
surefire m600
M4's by [email protected], on Flickr
anderson lower
psa lower parts kit
magpul ctr stock
magpul moe grip
delton 20 in upper
knights ras
aimpoint
Also-
Gen 4 FDE Glock 17 with streamlight TLR-1
Untitled by [email protected], on Flickr
budget build.
everything included was less than $400.
Diamond Back 9 in upper
anderson lower
psa lpk
magpul ctr stock
magpul moe grip
Originally Posted By: spasm3
Wow Jim, thats a Barrel!
22" Stainless fluted HBAR. 6-25x56mm glass. Just shy of 16# empty mag. Yeah, this build got a little out of hand......
Sure is. I think thats what I havein the back of my mind.
Also need to decide if I want 5.56 .308 or so,etching else. Choices, choices.
While in the airport in Hawaii on the way back here mid 2014, caught a glimpse of an AR pump (Guns and Ammo rag ??) to get around NY(??) regs.
Would meet the Oz uniform regs...who does them ?
If you don't have a .308, I really recommend one (the DPMS G2 looks great for example) but requires a dedicated lower. If you've got a standard lower, you might consider a .300BLK which is all standard parts except for the barrel.
I have three bare lowers left. One will be a .300BLK for sure.
I plan on buying a bolt action 300BLK anyway... Probably this:
http://www.impactguns.com/remington-mode...7700842059.aspx
Originally Posted By: bubbatime
300. blackout is a great hunting round too. Any AR in 7.62x39 is a complete waste of time since the .300blackout came out.
The .300 blk is a neat round. I would not say the the soviet round is a waste of time. It works for short range penetration and its cheaper to shoot. Cheaper to stock up for shtf.
Mostly Spikes parts, RRA NM 2-stage, Troy Alpha 15, Ergo grip, Griffin FlashComp, barrel is FNH CHF 16" made from the blanks used for M249 SAW barrels with the M249 spec chrome plating thickness.
