Originally Posted By: ET16
Originally Posted By: HerrStig
Not enough info to tell without a wiring diagram. has the car been hit recently? Normally, back up lights on older cars are fed from a common source, a swtich or relay, and each bulb has ground at or near the socket. A short into the power lead should light them both. What happens when when you go into reverse?
Strangely, it's just the one side. I'll pull it all apart when I can.
Most cars have a "light's out monitor" which tells yhou there is a light out somewhere, some have a system which is specific to the location of the bulb. THose extra circuits can make some strange things happen. There may be a printed circuit board inside your lamp assembly which could cause problems. The "good old days" are no more.
