Originally Posted By: CKN
I have use Stabil for several winters. When I start my lawn mower in the Spring I have no issues. My friends who forget to pour it in-typically take their mowers,edgers, etc in for a Carburetor rebuild due the carb being clogged with bad fuel.
That's not an apples-to-apples comparison.
First, you are here. On this forum. A forum for people that are a little off -- far more likely than most to take good care of their equipment. Confirming that, you are taking extra care when you put the equipment away. You probably take extra care with the fuel you buy, putting it into a clean, sealed, type-approved container. And replace the cap each time, don't let it sit in the sun, etc.
Basically, the people that use a fuel preservative are the people least likely to need it.
