- Joined
- Feb 28, 2010
- Messages
- 1,663
Originally Posted By: michaelluscher
I assume you did the basics?
Checked ignition system integrity?
Cleaned throttle body with TB cleaner and MAF with MAF cleaner?
Intake air ducting is all correct, no leaves?
Clean your IAC valve
I agree with all of this ^^^^^ plus it could be even a bad batch of gas, or poor quality gas your using. Could be several things. Have you hooked it up a code reader and see if anything comes up?
These are solid cars, it has to be something simple.
Jeff
Jeff
