Doing some research and I suspect my F150 suffers from the driveshaft "slip-bump" issue despite the one piece driveshaft. According to a certain Ford tech who has a youtube channel this is a common issue on both one amd two piece units and recommends greasing the spline whether they are between the two shafts or on the output shaft of the t-case. I would propose two questions.
1. Any possibility of grease contaminating the t-case fluid or causing issues?
2. What would the best grease be? Seems people are reporting return of symptoms after a short time with the specialty ford teflon grease.
