Originally Posted By: stygz
Can there be any negative effects changing oil brands? For example pp uses a different additive package than m1. Would the remaining oil from an oil change even make a difference? It seems I read an analysis that made a note about an oil brand change.
As to the root of the question...
"CAN" there be ?
Yes there can, and they CAN be nasty, but fortunately are extremely rare... e.g.
http://papers.sae.org/2000-01-2944/
Quote:
A taxi field test in 1999 resulted in unusually high used oil MRV TP-1 viscosity in the first 16,000-kilometer drain oil. A subsequent root cause investigation revealed that contamination of the test oil by carry-over of the factory-fill oil followed by oil aging in the vehicle was responsible for the unusual high MRV TP-1 viscosity. Contamination by the factory-fill oil alone cannot account for the high MRV TP-1 viscosity; oil aging in vehicles is an essential co-factor. While the precise mechanism has not been determined, high MRV TP-1 viscosity and yield stress appear to be the consequence of reduction in PPD effectiveness but not PPD degradation. However, the MRV TP-1 viscosity and yield stress of such used oil can be restored to acceptable levels by an optimized PPD system. The study found that used oil MRV TP-1 pumping viscosity and yield stress can be highly dependent on the viscosity index improvers used in the oils involved. However, oil robustness can be enhanced by a rigorous field test protocol.
But it's rare, even if it DOES affect the cold cranking end of the spectrum, how many operate their vehicles that cold ? (I can't even test the limits of 15W around here).
Also, as Quattro Pete points out, sometimes there's other evidence, like TBN.
Member KCJeep found that two oils when mixed don't always play nice.
Like I said it's rare, and it can happen.
Adding an oil flush means that you've now got some (small) part of an old, used oil, the majority of new oil, and now an amount of (typically) solvent to further confuse the issue...I wouldn't.
