Originally Posted By: supercity
You don't like the design or the method for adjusting it? I've always liked the simplicity. Very common on old DOHC engines and I don't mind adjusting them. Once you have a stack of shims from doing a few it's easy.
I don't like the method for adjusting it. I owned two Toyota 4s (a 1ZZ-FE and a 2AR-FE), and to my knowledge, camshaft removal was required on both to adjust the valves. You also have to match shims with lifters as I recall.
I prefer a simple adjustment nut on each rocker arm. It takes very little time to do, and no parts are required.
