Hi all: new member asking for advice,re packing bearIngs on fifth wheel. Have some Mystic red tacky grease, is this good bad or care to recommend something else? Thanks to all who respond.
I would check to see what axle you have. Dexter has a list of approved grease. Some dexter axles don't have to be repacked as often ( Dexter E-Z lube).
It does have Dexter axles, which are not ezelube. Have washed all old grease out and inspected bearings, looking for the best grease to use, as starting from scratch. Thought there might be a superior grease to replace the factory stuff.
I used Valvoline Ford/Lincoln/Mercury multi-purpose grease in the bearings on my HF folding trailer. Cheap and meets requirements for wheel bearing grease.
The Mystic JT6 high temp NLGI #2 grease would be excellent for your application. I use it in just about everything automotive ie. wheel bearings (including Dexter axles), u-joints, suspension and steering components.
