For the second time in a year, I've found a bad bulb socket in the Sedona. Earlier in the year, the front driver's side combination park/turn signal wedge bulb socket had a prong that wasn't making proper contact. Some bending with a pair of needle noses and it fixed the issue. Today, after noticing that the driver's side license plate bulb was out, I removed the socket. If I wiggled the bulb just right, it would turn on, then off, etc. Some bending of the prongs and sure enough, bulb works fine now. Of all the vehicles I've owned, I've never had a socket go bad before. This vehicle has had two go wonky... just an observation.
