Picked up the truck last year with 27K on her, now has a whopping 31K. Currently running SM Valvoline Durablend 5W30. I have some Dino SM QS 5W20 on the shelf. Questions are, should I run current oil through 2015 and put Dino in for next winter-concerned about shelf life?
As Im anxious to get current quality oil in her I may do early drain and run the dino this summer and change for better grade for following year.
Considering how few miles I put on her per year Im looking for a once a year OCI. Id like to use a full synthetic but can probably do well with a good dino. I'll probably go with a blend, what would you guru's go with? Im thinking Motorcraft or SuperTech full synthetic. How do they compare since they cost the same? Advice?
