Originally Posted By: BBDartCA
I happen to have my 2014 Subaru owner's manual open now (Forester). Page 12.6, 2.0 Turbo, states:
5W-30 synthetic oil is required for optimal engine performance and protection. Conventional oil may be used if synthetic oil is unavailable.
*: If 5W-30 synthetic oil is not available, 5W-30 or
5W-40 conventional oil may be used if replenishment is needed but should be changed to 5W-30 synthetic oil at the next oil change."
Second paragraph seems contradictory or maybe it supposed to just address a heavier oil (5W40)? Or perhaps there is a grammatical problem with the second paragraph. Maybe it should read "If replenishment is needed and 5W-30 synthetic oil is not available, 5W-30 or 5W-40 conventional oil may be used but should be replaced with 5W-30 synthetic at next oil change?" Who knows. Maybe the Science==>Engineering==>Language==>Japanese==>English translations aren't working well here. Whatever.
Anyway, the important part that's also on this page follows:
"OIL GRADE"
API Classification SM or SN with the words "ENERGY CONSERVING" OR "RESOURCE CONSERVING"
OR
ILSAC GF-4 OR GF-5, which can be identified with the ILSAC certification mark (Starburst mark). " and has an image similar to the below for reference.
The Forester has the 2.5L as standard so I do not know what the other engine you ref needs for lube. But if its the same as the 2.5, its 0W-20 Synthetic with the same verbiage as the above.
Who makes 5W-40 conventional oil ?
