when I changed the thermostat, I opened the petcock to bleed out the air, which some bubbles appeared then were gone, however I never did get the coolant to run out in a straight stream out of the petcock hole even after the thermostat was open and the system was circulating...on my lucerne with a 3.8 after the air is out i get a stream of coolant...on the lacrosse I did not? just wondering
