Need some help with a Troybuilt 27 ton log splitter. Has a Honda GVC 160 5.5hp.
Would run but die, I disassembled carb and cleaned it as there was some gum and the main fuel delivery Jet where the float valve operates was partially clogged.
I cleaned that and blew all orifices I could see with carb cleaner. Reassembled and engine will stay running but if you open the choke fully it will die. Did I miss cleaning something?
Thanks in advance for your comments.
on edit: Title should say dies with choke open. So Engine will only run with choke fully closed.
