Got a tax refund this year, first in ages, so decided to do a few things out of the norm.
Plastic rocker covers on the L67 have been a bit drippy, so lashed out and bought a set of polished alloy ones...and thought that while in there I'd put some higher ratio rockers in...inlet only.
Straight bolt in mod, to augment my 10psi pulley.
Varnish with the rocker covers off was worse than my fill hole pics, quite seriously. Red/Brown, and quite rough in spots...no pics, but I do have the old covers, and will post a pic of them in my varnish thread.
Put the new rockers in, and ended up with every inlet valve cracked open...apparently the lifters refused to bleed down to accomodate.
Will be contacting the supplier to make sure that they sent the right bits...but in the absence of that being wrong. looks like there might be enough gunk, despite all my flushing efforts to have kept the lifter from running full stroke...maybe.
