Originally Posted By: clinebarger
Originally Posted By: EvanD
I need my 4l65e rebuilt annd beefed up a little. Really how hard can it be to do. Toss in a few new parts check a few clearances follow a manual.
Has anyone on here tried it themselves. Not being cheap. It has to be possible by a backyard mechanic.
Did I read somewhere on here you are going to Super Charge your LQ9?
Do yourself a favor & install a 4L80E, A Stock 4L80E with a good converter will handle more power than ANY 4L60E/4L65E no matter what parts are installed, Who builds it, Or how much money you throw at it.
The 4L65E has some major weaknesses....
The 3-4 Clutch diameter is to small, The band-aide for this is to add more friction plates, To do this you have to reduce the thickness of the steels & frictions, It does increase friction area but you lose the ability to shed heat. The 3-4 clutch builds ALOT of heat. Sonnax makes a Input Drum to accept 9 full thickness frictions & full thickness steels, However the Input Drum cost over $600.
The 3-4 Apply Piston is to small, It just CANNOT apply enough clamping force to the 3-4 clutches to hold big power. No fix for this...And never will be.
The Turbine Shaft is pressed into the aluminum Input Drum, High HP/Torque will crack the Drum, Sonnax Input Drums are sleeved.
The Forward Input Sprag is weak, A 29 element Borg Warner sprag is the best you can do. Under heavy abuse the Sprag Race will bust, No fix for this.
The Reaction Sun-Shell is weak where it splines into the rear Sun Gear, The Sonnax Smart Shell fixes this.
Pump Vane Rings break, From increased load from higher line pressure &/or high RPM, Trans Go hardened pump rings fix this.
Actuator Feed Limit (AFL) Valve Bore wears in the Valve Body, Causing lower than commanded clutch apply pressure, Reaming the bore to a larger size & installing a oversized AFL valve is the only fix...The Jig & Reamer kit alone is $400., At 200K you HAVE AFL bore wear.
TCC PWM Isolator Valve Bore wear is given on this unit, Trans Go has a valve to fix this without Reaming/Oversized valve, Though in my opinion reconditioning is the "correct" way to fix it.
Planetary Lube Circuit has low volume, 99% of Planet failures are lube related, No Fix...GM did all they going to do. It is better than it used to be in the early 80's 700R4's, That's not saying much. 250,000 is the max life expectancy, Some Go more, Most go less.
A 4L80E swap will require.
2500HD Cooler Lines.
ISS connector & minor wiring mods.
2500HD Flexplate, Spacer, Flexplate bolts.
6 Torque Converter bolts.
Transmission Crossmember mods, Fabrication required.
Shortened front section of the Drive Shaft & balancing.
4L80E "Segment Swap" in the PCM, (Tuning).
I have been building 4L60E's & 4L80E's for over 20 years, I'm willing to help whatever route you choose to go.
take it to this guy.
