I will be replacing the front wheel bearing/hub assemblies, outer tie rod ends, and struts on the GP in the coming weeks. My plan was to do the work on a Sunday afternoon and have the alignment done at a local shop that Monday morning. However, I just found out that I have to travel for work on the Monday on which I had planned to have the alignment done and that travel will require me to grab a 6:00 a.m. flight at an airport 50 miles from my house. Is it okay if I drive 100 miles following that work before getting the alignment done or should I push the work back one month (which is the next time I have availability to do it)?
I realize that I can do my own alignment, but I may not have the time to do a decent job considering how slow I go when working on my cars.
