Originally Posted By: il_signore97
Originally Posted By: SHOZ
I have a 2010 6sp manual Genesis Coupe. The clutch is very hard to get all the air out of the slave cylinder. What's the best way to bleed the clutch?
The bleeder screw is between the clutch master cylinder and the slave cylinder. The slave cylinder is on a dead end piece of tubing. If there is air in the slave cylinder how do you get it out?
Especially if you have the car jacked up with the front higher. I'm thinking it needs to be higher in the back so the air bubbles will travel from the slave cylinder to the bleeder screw.
Does the level of the car come into play?
Here's a pic of the slave cylinder.
Sounds like a really dumb design. Have you tried getting your hands on a copy of the factory service manual for your car? They must have a "proper" procedure written out in there for the techs to use. Perhaps someone on one of the forums can look it up for you and send you the relevant pages if you don't have one.
I posted the manual procedure in a couple post up but the picture has disappeared. I really think my problem is the car is not level when I am doing this.
