Since the Mazda 6 or CX5 is in the running as a strong contender as my next car, I would like to know if I may have to deal with enginneering quirks. I would get the 2.5 liter Skyactiv engine. I believe this is a non-interference engine. For example, I would like to know where the fuel filter is located. Online sources vary on the issue, with some claiming the filter is below the filler neck, while other say the filter is part of the fuel pump. Do Mazdas require any special tools for common maintenance jobs? Can the service indicator be reset without a special tool? Can the brake system be serviced without having to cycle the ABS pump with an electronic gadget? Any kind of information pertaining to positives and negatives is apppreciated!
hotwheels
hotwheels
