The PDS for Castrol's Import Multi Vehicle ATF says it is Ford approved for Mercon V.
It is not the same fluid with a different name. The PDS specs as well as the MSDS shows it is different to the Mercon V. In fact, from the PDS, it looks better.
I've read the expert opinion being generally against multi vehicle fluids. But we're seeing more of these multi vehicle fluids with approvals.
So which one is better for a Mercon V application? Just a Mercon V product or a multi vehicle product such as Castrol or M1?
