OVERKILL,
That's from the new MSDS for M1 0w-40 in Germany, dated November 21st, 2014. It shows 50-60% PAO now.
I took a look at my favorite German shop where I buy oil, and indeed I see that Mobil 1 NEW LIFE 0W-40 is marked as Vollsynthetik.
The full list of specs is:
Eigenschaften: Vollsynthetik
Freigabe: ACEA A3, ACEA B3, ACEA B4, API SJ, API SL, API SM, API SN, BMW LL 01, MB 229.3, MB 229.5, Porsche A40, VW 502.00, VW 503.01, VW 505.00.
They say that this oil is also recomended for: API CF, OPEL GM-LL-A-025/GM-LL-B-02, FIAT 9.55535-Z2/FIAT 9.55535-M2/FIAT 9.55535-N2, SAAB.
More details (in German) can be seen at
https://www.autoteile-meile.ch/Oele/Mobil-1/NEW-LIFE-0W-40/p-OIL-29
If you wish to see more Vollsynthetik oils from Mobil you can use the following filter:
Mobil 1 PAO oils
If you wish to see full Vollsynthetik list you can use the following filter:
PAO oils
