Curious if I got close, been too long since the last time I did this.
On my 'yodas I just did a drain and fill. To the top. I started and let it idle until I got some heat. Then capped and called it good.
As it cools down I'm going to check and fill the overflow tank, as required.
Right/wrong? I know they thermostat didn't open but it should still circulate, right?
