MAJORCAVALRY
I almost bought one of these Acuras myself, but opted for a big SUV for my big family's needs. Most modern engines have this issue, but some more than others. What is happening is the oil is being fed through the pcv/vacuum tube and back into the intake. Thus the reasoning that a lot of manufacturer dealers are suggesting a intake cleaning service every 15k miles or so to clean out the oil in the intakes and throttle bodies as well. This oil build up is not good for the intake or the catalytic converters. I would suggest getting yourself a catchcan at catchcans.com I did this on my GMC which had the same issue and problem solved. I am by no means an expert or certified engineer or technician for that matter but do work in the industry and know a good deal about today's modern engines. This was just my $.02. Good luck!
