If I recall some Saturns may have oil consumption issues, as one or two users(more?) have frequented this site due to the coking of the oil control rings on the pistons with these cars. Not sure if this engine is the same sort or a less prone one.
So, monitor your oil level and get an idea of if/how much it consumes. I'd check at least once every 1k miles on your first oil change or two. If it drops below the full mark be sure to keep it topped off with that 1/4 or 1/2 quart of oil.
If you wind up with any consumption switch to a high mileage oil and perform some shorter intervals for a while. T5 10w-30 is a solid oil, but if burning oil I wouldn't exactly go for a HDEO. At least not for long-term use.
Do these cars have a PCV valve? Find out and check/replace if necessary.
Off hand, T5 sounds too thick for NY in the winter, but maybe this car would like it if consumption weren't nice on typical gasoline engine oil.
