8 or so weeks ago my well stopped producing water.
Called a guy out and he was beyond expensive. Called a 2nd guy out. Much more reasonable. Determined that the pump is shorted.
Also determined that the water level in the ground is pretty low.
I decided that I cant afford to drill a new well so I asked them to put in a new pump and i'll see what happens.
They came out and put in the new pump and some new drop pipe. All said and done...No water!
They took their $2800 and left. Called a couple days later with an estimate to drill a new well.
Panicked I started thinking. I bought a 275 gallon tank, pump, hoses etc and I have been hauling water every other day.
So I did my own investigating. I measured the well casing, water depth etc. I determined that the casing holds 68 gallons of water and it will take 18 gallons of water to fill the drop pipe.
Hense I should have atleast 50 gallons of water on the ground if I turned the pump on.
I had nothing!I called ,They came back out and measured the water then left.
That night I slid the well cover over and listened. It sounded like a water fall in there!!! Pump was pulling amps like it should.
I called them and told them that I believe the drop pipe is broken.
They came back out today and pulled the first 60 ft of pipe out to get past the check valves in the drop pipe. Then dropped an electric water sensor down the drop pipe. Determined that the new pipe @ the 220 ft was where the water was standing.
So they pulled it out and I was right! The pipe was cracked!!!
Put a new piece in and its working again.
I'm irked in the fact that they were so fast to decide that my well was junk and the only repair was to redrill @ a cost of about $20000.
Yes mistakes happen. But IMO they jumped the gun instead of figuring out the problem.
I have been hauling water for 8 weeks, bought pump,hoses etc due to their goof. Plus stressing over trying to max out all my credit cards to try to pay $20K for a new well.
They did fix it today @ no charge.
Do I have a reason to be irked or am I being stupid?
