Originally Posted By: Cujet
The new Corvette is a bit out of reach, even so, it's having engine problems.
If you're referring to the Motor Trend (?) engine failures, those may have been from a dealer or someone else using PF48 (e-core) oil filters instead of the correct UPF48R "Ultraguard Gold" filter. The UPF48R has a steel cage instead of e-core and is designed to handle higher oil pressure.
