Originally Posted By: sir1900
Originally Posted By: camrydriver111
I have a vehicle that based on my driving patter will require only one OCI per year. I'm doing ~8k miles per year and 95% city driving on synthetic oil. What would be the best time of the year to change the oil to maintain best oil performance throughout the year?
Would it be the best to change it before winter in November or right after winter in April? I imagine winter operation is harder on the oil than summer. Would you want to have the freshest oil with the most additives in the winter, or would you want "broken-in" and sheered oil in the winter and dump it in the spring? Does it even matter unless I'm looking for some sort of ultra long 20k mile OCI?
Generally speaking, it doesn't matter, but spring would probably be the better time as the oil is pretty beat up with the constant stop-and-go during the winter months.
Again, won't make much, if any, difference. Change it when you have time.
This is true. The oil will get more beat up in the winter.
However wouldn't you want the best TBN and cold flow properties in the winter?
If I change it in the spring once winter comes I will be using oil that has been in service for ~8 months. The TBN and cold flow properties won't be as good, although they should still be relatively strong.
I guess that's why we have UOA, otherwise we could speculate all day.
