I have several qts of Edge 0w40 and just got a 97 Explorer 4.0 sohc. I am going to try it and see how it does, does anyone have any experience with this oil in this motor?
Sounds like a decent combo since the Ford 4.0Ls called for 5w30, might be able to mix some 0w20 in if you find a good deal. But no biggie on the 0w40 IMO.
Originally Posted By: jfug97
so the only difference from 5w30 will be a little less mpg?
Yes, keep in mind that engine can use a thinker oil. It has 4 timing chains that shear down the oil given change. One of the few engines Ford never back spec'd to a 5W20 oil
