OLM was at 19%. Filter was NAPA Gold 7060.
Blackstone Comments:
Copper improved this time, but lead is going the other way. Lead might be a sign of bearing wear, so it's an important one to watch, but there's still a chance that the lead in your system is just coming from the new radiator you installed prior to the last sample, rather than any sort of bearing issue. Hard to say for sure at this point, but keep an eye on the oil pressure, and stick with 9,000-mile oil runs for now. If lead continues to increase, and especially if copper or other metals increase, it may be an issue. Hopefully, though, it will go away on its own soon.
Code:
MI on Oil 9,083 9,074
MI on Unit 135,057 125,974
Sample Date 10/11/14 06/15/14
Make Up Oil Added 0 qt .5 qt
Oil Type PU 10w30 PU 5w30
Universal Avgs
ALUMINUM 3 3 4
CHROMIUM 1 1 1
IRON 11 11 23
COPPER 30 53 48
LEAD 28 18 8
TIN 0 0 1
MOLYBDENUM 57 56 73
NICKEL 1 1 1
MANGANESE 1 1 1
SILVER 0 0 0
TITANIUM 2 2 2
POTASSIUM 1 2 2
BORON 27 33 51
SILICON 10 5 10
SODIUM 4 4 37
CALCIUM 2372 2113 2009
MAGNESIUM 33 29 335
PHOSPHORUS 727 659 738
ZINC 870 808 865
BARIUM 0 0 0
SUS Viscosity @ 210°F 60.8 58.8
cSt Viscosity @ 100°C 10.44 9.88
Flashpoint in °F 410 410
Fuel %
Antifreeze % 0.0 0.0
Water % 0.0 0.0
Insolubles 0.2 0.1
TBN N/A 3.2
The lead creeping up is a concern. The next UOA will show if it is trending upward.
Previous UOA is here .
Code:
Universal Avgs
ALUMINUM 3 3 4
CHROMIUM 1 1 1
IRON 11 11 23
COPPER 30 53 48
LEAD 28 18 8
TIN 0 0 1
MOLYBDENUM 57 56 73
NICKEL 1 1 1
MANGANESE 1 1 1
SILVER 0 0 0
TITANIUM 2 2 2
POTASSIUM 1 2 2
BORON 27 33 51
SILICON 10 5 10
SODIUM 4 4 37
MAGNESIUM 33 29 335
ZINC 870 808 865
BARIUM 0 0 0
Fuel %
Water % 0.0 0.0
Insolubles 0.2 0.1
TBN N/A 3.2
