Originally Posted By: CATERHAM
Originally Posted By: weasley
Originally Posted By: MolaKule
I have yet to see any current additive package with particles large enough to be filtered out.
No, but if the detergent and/or dispersant are bound to a larger soot particle, this can be filtered out, and the additive stays with it.
There are some techniques that can distinguish between active and spent additives. It's worth noting that some additives 'metabolise' in use and form new structures that are, themselves, useful molecules. ZDDP, for example, and some antioxidants.
As stated though, if you test for Zn, all you know is how much Zn is in the oil, not what form it is in. Actually it is the P that is more pertinent to the wear protection, but the same applies. When the ZDDP is oxidised and exhausted, there will be zinc oxides and simple phosphates but these do nothing to help performance. NMR can tell you what's what, but no run-of-the-mill lab will have one.
weasley is there any existing data that provides the rate of ZDDP depletion in typical PCMO useage as mileage accumulates?
I'd like to see the same for boron and any type of moly as well, since many in the additives forum are giving me a very hard time for wanting to add more of these to the middle/end of an OCI, to make up for the natural depletion.
