Originally Posted By: Thermo1223
Originally Posted By: Miller88
I don't like having to pay a shop to disassemble the front of the engine to change a glorified rubber band ... and if I don't spend $1000 to do that, I have to buy a $3000 engine.
Instead, because I have a timing chain, I don't have to worry about it.
Yes, there are timing chains with problems .. but EVERY timing belt will fail.
You are so FULL of wrong where do we start?
Is your serpentine belt a "glorified rubber band" as well?
Since you've never owned one how would you know what it cost?
Every timing chain will fail as well, some much sooner than you would ever believe. Nylon gears, but chain guides, bad tensioners, chains are not immune to anything.
Having to completely redesign the engine to get oil to the chain as well.
There is no agree to disagree....you are just plain wrong.
If my serp. belt snaps, nothing is going to break. I won't be replacing valves, pistons, etc.
It seems like VW and other manufacturers have you trained to believe it's acceptable to have to spend money to maintain something that should be lifetime.
Many high mileage OHC engines with chains ... not a problem.
YOU are in the wrong.
But that's okay. I'll spend my money on fun ... where you can spend it on changing a timing belt haha.
Every timing chain will fail ... But the Ford modular v8s with 500K miles ... are still waiting for it to fail.
