Let's see, I've installed an M5 (it's previous iteration) and an M6-32 SuperCluster in the past year. Will do a half dozen more come January.
There are 6 3 phase power feeds supporting 12 7kw power supplies. Of course, it's built for redundancy, so it should only need 6 of those 12 power supplies or about 42kw of power.
I believe the max rated current draw for the M6-32 is 48A at 200-240VAC per power cord. Which seems consistent with what 6 7kw power supplies would provide doing the math in my head.
You can see the details here:
http://www.oracle.com/us/products/server...-ds-2015584.pdf
If you decide to put one of these in the basement of your home, make it easy on your installer and provide the power from the ceiling as the power connections are on the top of the machine.
Originally Posted By: The_Eric
Originally Posted By: simple_gifts
Oracles new M6 machine supports 32Tb of system RAM and has 384 processor cores, supporting 3072 simultaneous program threads.
Ummm... HOLY %^$#@!
I think I need something like that to properly surf the web!!!
Don't want to derail the thread, but I wonder what it's power requirements are?
