Originally Posted By: coopns
02 Camry, driver side door has a fairly loud 'wind' sound. Top of the door, it is not the window. I tried the radio up/ignore. I was thinking about some of that door/window rubber/foam...maybe a small strip of it?
Any ideas?
You can replace the rubber as it ages over time. If you have a solid base to stick to you can use self adhesive stripping(I did in my 07 MDX with prior body damage and it is quieter on that door then the "good doors"). The tiniest leak can make a lot of noise.
