Honda MM question
Originally Posted By: lawman1909
Mine states what I posted first. Must be Honda then, not me.
Page 279 from the 2014 CRV owner's manual:
I don't see where...
Quote:
it clearly states "Full-synthetic is not recommended...
I too have that page. However, mine specifically mentions Hondas oil as what is recommended. It goes on to say that full synthetic is not recommended. But thanks for showing me that, reinforces using M1 0W20! Cheers
Not if "full synthetic is not recommended," as per your special owner's manual.
This is going nowhere.
To the OP: You can use whatever oil you want if it meets the grade and certification set by Honda. Whatever 0w-20 oil you choose, change it by the MM.
The owner's manual makes no recommendation regarding synthetic oil, other than to say that it can be used as long as it displays the API seal and is in the correct grade, 0W-20.
Not according to what lawman1909 claims.
Originally Posted By: BTLew81
They say 0w20 but dealer has an info sheet saying 5w20 is fine but 0 will provide better fuel econ. Took a pic of it.
They say that for 2014? This is the current lubricant recommendation at Honda dealers:
Granted...that was current in 2013, but every Honda's been on 0W-20 since 2012 (and the CR-V since 2010). In almost all cases, they have listed 0W-20 as "acceptable" in older models that originally recommended 5W-20.
If Lawman's owner's manual differs from the image that you posted, then I'd love for him to provide a photo.
