Originally Posted By: RangerGress
We, the naysaysers and I, may have to just agree to disagree.
The ED truck weighs ~4% more than the Hemi truck. No way that weight is the cause of 25% reduction in towing capacity. Once you go read up on the J2807 standard, you'll see what I'm saying re. it being oriented mostly on WOT up steep mountains. There's 2 engine tests, a handling test, braking test, and hitch structural test. Are you going to argue that the ED, relative to the Hemi, doesn't handle or brake as well, or it comes with a weaker hitch?
Here's a good discussion of J2807:
http://www.automobilemag.com/features/news/0912_sae_tow_ratings_finally_pass_sniff_test/
Sounds pretty good to me. And seems to be more than WOT up mountains. It's maintaining speed, braking, handling, etc. IOW the whole package. It's also not mandatory.
I don't know what the difference is between the 2 and I'll never find out as I'll never, ever own a Chrysler vehicle (I think we all know that). But there is a tangible difference!
But what possible reason would they have to not say it will tow as much as the Hemi. There has to be a reason. There has to be a reason the Ecodiesel's payload is way lower than the other Ram's (which are lower than the competition). By your own admission the 4% increase in weight is offset by a huge amount of payload decrease. Something has to be giving there and only Chrysler knows the answer.
Quote:
The whole "maimed or killed" makes good copy, but it's alarmist foolishness.
Really? Exceeding the capability of any piece of equipment is not a good practice. At some point it will bite you where the sun doesn't shine. Maybe not today, maybe not tomorrow but someday.
Quote:
In fact, the handling and braking of modern trucks is an order of magnititude superior to the trucks of the 80's and 90's. Certainly the 1/2 ton ED handles with vastly more "certainty" then my old (2000) F-250 did.
It's also 15 years newer with newer suspension components. I'd hope a new vehicle would handle better than a 15 year old unit.
Quote:
I used to think like you. I was sure that it was patently unsafe to tow a large fraction of the rated weight. I'm not longer so exciteable. All a person needs to do to safely tow their rated weight is to make sure their trailer brakes are in good order, and distribute the weight in the trailer such that the tongue weight is right. Then just drive like a responsible adult and it will be fine.
And again, with a payload less than 900 lbs what are you going to tow with an Ecodiesel and not be overweight? A family of 4 and stuff (4x200=800lbs) and you're done before you put a trailer on!
Quote:
Cost of diesel. As you'll see discused in my links above, diesel isn't that expensive if you shop around a bit. I ran 89 octane, mid grade in GA, in my '06 F-150. Altho rated for 87, I figured it would be better to up a grade for towing. The price delta for diesel is much larger than what you normally see for gas. Within a mile of my house gas prices vary by ~10cents, but diesel by 50cents. What that means is that you have to shop a little harder for diesel. I can always find diesel for ~10% more than 89 octane. The Ram gets 1/3rd better mpg as a DD than the F-150 did, and almost double the mpg when towing.
I'll let everyone use Gasbuddy. Here's a sampling:
Sheetz, a large convenience store chain today:
87 Gasoline: $2.55
Diesel: $3.29
Flying J:
87 Gasoline: $2.57
Diesel: $3.29
Not sure if these are state differences but this is in PA, in a trucking heavy area too.
Again, I can do an oil change with a top synthetic and a top filter for ~$40. According to the link I provided, the Ram guys are excited for "only" $80 DIY oil changes in their units. They are both 10k OCI's so I can do mine twice to your once.
Quote:
Re. "Chrysler did the engineering on the truck, they did the testing, and the #'s are what they certify it to be safe as." That's not accurate. It would be more accurate to state that "Ram's marketing department asserts the performance is up to those #'s."
And if the marketing department thought they could get away with higher numbers they would!!! Something is holding them back and I don't buy it's just J2807. If it is then Chrysler is a much worse engineering company than I thought. My guess is it all ties back to the low payload of the Diesel truck. But what is anyone's guess.
