Originally Posted By: Dallas69
You clearly have not been on here enougth
You never have too much oil
If you're not joking, then I would have to disagree. I already have enough oil in my stash without buying the NAPA Synthetic I plan to buy in the future. I also have an oil filter stash that I consider to be more than enough because quite a few of them (not most of them, but quite a few) are cellulose filters, and from what I have read on BITOG, storing cellulose filters might not be a good idea due to the paper degrading/becoming brittle over time. I am storing them in a temperature controlled environment (inside my home); thus, moisture should not be a problem, but some moisture/humidity might still affect the cellulose over time.
So, I will not buy any additional oil filters until I use up what I have ... and after I buy the NAPA Synthetic, I will not buy any additional motor oil until I have used up my stash. Then I will buy what I need when I need it. That is what I used to do before I started following BITOG, and I am going to return to that buying practice in the future. Moreover, buying what I need when I need it gives me the option to buy whatever oil/oil filter I feel like using at the time.
