Originally Posted By: The_Eric
My suggestion would be to move back to a .45 ACP cartridge in a poly pistol. Sure, you give up some capacity to the 9mm, but if you're shooting at a bad guy with a pistol, your rifle is probably toast and you're probably standing toe to toe and want him to go down. .45 ball still gets it done quicker than ball 9mm.
Rifle?
What rifle?
19Ks (M1 Abrams armored crewman) do not qualify with a rifle. No point in having the fool thing that will just eat up space and is inferior to the 2 7.62s, the .50 cal, and the 120mm. We spent a couple of days familiarizing with the rifle, fired it once, and then the only time I ever touched a rifle was when we were in garrison. Cleaning crunchy weapons was common busy work.
Throw track? you're a pillbox. Throw track and run out main gun ammo? You're a bunker. If you have to bail out of your track, bad stuff is already afoot. You better have a good pistol.
9X19 is standard NATO. I vote for an HK MP5 Compact...at least for the loader and driver.
