Originally Posted By: HTSS_TR
Originally Posted By: ltslimjim
Yes, I didn't link the other threads but I have created/posted this application for my bro-in-law before (as you can see the previous UOA results from before, the first was Amsoil ASM 0w-20 before it was labeled SSO and the rest all AFE 0w-20; IIRC).
He has a nice engine. He doesn't do a ton of short trips either.
I'm trying to get him to venture out to other synthetics for the same mileage or 1 year, but not dice.
PS: Any thoughts on if he should change oil filter at say 10k or 12.5k? He is using a Mobil1 oil filter for the full duration still. My suggestion was to change the filter at say 10k miles, top off the oil and that way he can repeatedly get 1 year/20k no sweat without worry of filter capacity being reached; though not likely if the engine is fairly clean anyway just a thought about more headroom for the life of the vehicle from here on.
NOTE: This was API-SN in case anyone wanted confirmation.
No reason to try other brands when M1 0W20 shows this result. M1 0W20 is this good (TBN 2.4) after 21k miles who needs M1 EP ?
No need to change oil filter half way, actually keeping the oil filter for the full 20+k miles OCI is better because it's more efficient as miles increased. There is little debris in a clean engine to filter as long as the air filter is in good shape.
The last time I changed the oil and filter in my E430 the cartridge filter was in great shape after 23k miles(2 OCI's of 11-12k miles), I thought about keeping it in for another OCI but I have many filters in my stash so I changed it.
Exactly.
I'm no fan of M1 but with data like this only a fool would change brands just gor change sake.
23000 miles is enough to make some here brains melt.
Kinda blows the 3000 mile interval out of the water doesn't it b
As far as filter goes there's no problem running a top tier filter the whole interval. I use tough guards for up to 30000kms now and upon dissection there's nothing saying I'm overdoing it.
The media isn't so loaded that I feel it's going into bypass,in fact if I didn't know there was 30000kms on the filter I would never guess it.
