Originally Posted By: Kiwi_ME
Being devil's advocate here .. in the end every brushed motor has to start from stationary and the conditions of no back EMF and therefore high current through the commutator are always going to be present. I find it difficult to accept that the conditions of low starting voltage (say 9V) does more damage to the commutator than 12.5 V or higher, and that it doesn't just start turning anyway since there is nearly zero load.
You're correct, letting the fuel pump run before cranking doesn't help the fuel pump last longer... but people perceive that it makes a difference because it does, in fact, let a weakened/failing fuel pump build enough pressure in the fuel rail to start the engine when it *is* cranked, whereas it might not be able to do so when the starter is also drawing a very large current. Once a fuel rail is pressurized the engine can start even if the fuel pump quits running during cranking. Try it some day- pull the fuel pump fuse with the engine running and you'll find that the engine can run maybe 10-15 seconds (at idle, of course) before the fuel rail pressure drops too low for the engine to run.
