Originally Posted By: 7055
Originally Posted By: spasm3
Burn the old one out, press the new one in.
That won't work, I can't burn it out, the circular metal piece that needs to be pressed in/out won't burn out. I think the only way is to remove the whole strut and take it to someone with a press. Or if maybe I can find a way to get it out myself.
Yes you need a press, or someone who has one. Depending on your shop/garage a press can be had for around $200 for a harbor freight 20 ton. I have a 12 ton, i wish i had gotten the 20.
