Originally Posted By: motorcity
On this model blower, I have found that you need to use the Ariens OEM belt. Its a od length and the aftermarket equivalent just doesn't work right. Another thing on this blower, is the spring for the chute detent ball breaks. And the chute will move on its own. I was able to match up a spring from the hardware store, and it had more tension than the OEM spring.
I have this exact model. A great running snow thrower. Thanks for the comment. I have the same issue with the chute and will look at replacing the spring. Skid bar, belt and wheels are all I had to replace on mine after many years of use.
