The shutoff valve (screwed into the gas tank) for my 8 yr (or so) Airens 36" snow blower is leaking gas. Before use I unscrew it one or two turns and run the snow blower and when I am done its open about 6 turns and leaking. So I assume its loose and vibration is opening it more turns.
Is there an o-ring in there or some other packing or does the shutoff valve need to be replaced?
